Z-wave thermostat stopped reporting updates to hub
Hello,
Since the last two or three software update my 2 Z-Wave Thermostats from Trane do not provide an update back to the hub. I can send changes which they process, but on the Dashboard no update is done , means I can not see any changes and need to check on the Thermostat .
This worked very reliably before, but not now anymore. That’s really hindering !
As I read the incident is this related to it ?
Thank You !
This has nothing to do with the incident notice you replied to so I moved it to a new thread.
Read this below:
I would also add to what @jtp10181 when mine stopped reporting (Honeywell t6 pro) I simply power cycled the thermostat (pulled it off the wall and then also removed the batteries) and powered it back up and has been running fine since.
