If you turned off all z-wave devices (actually disconnected the power) Do the reboot procedure I oulined above, then continually hit refresh on the ghost line till the remove button comes up. The only other options are to take it to another location where there is no signal at all or use the seperate z-wave stick
Thanks. The Remove button appears immediately on three of the items. But when i click the Remove button, the browser whirls busy for abt 30 seconds and then refreshes the page. the items are still there.
And i restarted the c7 after each attempt. No luck.
THe first object is different. It shows NOT RESPONDING and never exposes a Remove button
And what does the Log entry posted above mean;
"Z-Wave Network responded with Busy message"?
it means a device is still pingable. After you hit the remove button once or twice, wait. eventually youβll get a force remove popup
Kenny, I recently ran into this issue of ghosts I didn't know I had. Once found they were quit stubborn. I had not yet purchased the "stick" device to remove them as part of my reluctance was I understand it requires a PC and I am a "Mac" guy. Anyway, my last resort was resetting the Z-Wave radio on the Hub. That did clear the Ghosts, HOWEVER be warned it resets ALL Z-wave devices. I knew that going in and then very painstakingly re-added each of my 24 (about) Z-wave devices, one a time, rebuilding my Z-wave mesh. Of course that is following the thought process of, "If it doesn't work, get a bigger hammer". Yes, that worked for me and my ghosts have gone on to the other world, but if you have Windows 10, I suggest the advice from these many well worn travelers before us, the stick may be your answer. (Although, I like the idea of escorting the Hub away from society and if there is nothing there to ping... I wish I had thought of that, I would have tried ...) Understanding this is a Z-Wave issue not really the HE to blame.
I dont really want to go that route.
I shut power to the building and attempted to remove devices. Still getting the same non result. And the same log entry. It must be one of the battery powered devices.
Yeah, gotta disconnect those too
I too have issues with my Z-Wave network that just started recently. devices I do not put in exclusion mode, excluding from the network when I try to exclude a different device, and refusal to include the device back in. For me, when it does include, the hub just hangs, instead of presenting me with an option to name the device, and the device goes into what I assume you are calling ghost mode -- the device appears in the z-wave devices list, but there is not associated device in He to control it. In the very rare case I do get the hub to detect these devices, it just hangs (as stated).
i may try to build a faraday shield outta the wife's strainers. then wrap in foil. It would look like a disco ball hanging from the wall...
That usually indicates you have ghosts in your z-wave table. When that happens you have inclusion issues
Can you post your z-wave table?
Aside from having to manually edit my dashboards, and rules, I was able to get the system to work. I decided to go ahead with removal of a gen 1 z-wave dimmer, and installation of the new dimmer. So, I had to kill power to that wall (which has 7 z-wave dimmers and switch). The hub stayed on, but that seemed to clear it, because immediately after restoring power, the hub started pairing again. I won't pretend to understand this stuff. I learned the command specifications, but never dug into how the radios work, or how the pairing process works, so as weird as this sounds, I just have to accept it is working now.
Still if you have any ghosts, itβs best to eliminate them. Also the more paired with security (especially s0) slows things down a lot. The only thing that should be paired with security are locks
Yes. PLease tell me how.
no ghosts... Every device in the list is accounted for, and was accounted for before the power reset. I am left with only one device that won't pair now, and I may try to replace it with another, as it is an inexpensive MonoPrice Z-Wave Plus recessed door sensor, and are problematic to pair in the first place.
rlithgow1
How do i post my z-wave table from HE? I am assuming your post was directed at me. Thx
just use the snip tool in windows
Of course. I was looking for an Export feature. I posted the table entries of the 4 devices above. Is that what you were looking for?
Actually i realized i posted in response to @armand to try and help him. You seem to have a handle on getting rid of your ghosts and being on the road to recovery
