I have a C7 running 2.2.7. All my light switches are Inovelli Z-Wave Plus red series dimmers. Anything directly controlling the light works. However, anything with a rule attached to it was running very slowly. (e.g. the basic turning on, a "1 push" was fine, but the rule that says to control that same light, but set it to 35% with their config button, a "7 push" was very, very slow (35 seconds or longer or didn't work at all).
So after resisting all these months I decided to finally do a Z-Wave repair. I saw it go through 2 times - the 2nd pass to "repair" a significant number of devices that "failed'. On this 2nd pass only 1 of those that initially failed was now repaired. However, when I refreshed my Z-Wave page I didn't see anything saying they weren't working and, if fact, virtually all of them showed a cleaner path (many being direct from the hub to the switch even though they are 600 series Z-Wave Plus and not 700 series) and at 100. However, many, many of my automations are not working at all now!
From that example above, about a 7 push the log said:
CentralSceneNotification(keyAttributes:0, scene Number :3 sequenceNumber :211) and nothing else. After a bit I see more activity in the logs, but the light still hasn't come on.
Should I run the Z-Wave Repair again, let it sit overnight, restore a backup?
Here is the Z-Wave details for this switch:
