Z-wave polling seems to be failing on my C7 running 2.4.0.144. I have some old GE non-Zwave Plus devices and they only work when I force a Poll command but not using the z-wave polling. Any ideas?
I would suggest hitting "Done" in the Z-Wave Poller app to get the scheduled job going again, the most likely culprit behind your problem.
That seems to have worked, thanks. Just another reminder for me to upgrade those switches.
Well, the issue has returned after 1 week. For some reason the Polling app appears to go dormant after a bit. Hoping someone can fix this bug? Now running 2.4.0.145 but otherwise the issue is the same.
I find that many things around here are buggy or break with updates. I created a rule machine rule that polls selected devices - you might try that.
Still not working using the official polling app. I can re-start it and it might work for an hour or a day but then just stops for no reason. Thanks to acr2001 for the recommendation to create my own polling rule inside Rule Machine. That seems to be working ok for now.
