Z-Wave Polling appears to stop after some time
I start z-wave polling with logging turn on. Can see the polling in the logs but then after some time the logging stops of the z-wave poller stops. At this point I can't tell if its not logging or if its no longer polling.
If I go to the Z-Wave Poller app and turn off logging hit done then go back in and turn on logging then check logs there are still no poller logs.
Can you tell me if Z-Wave Poller is still running?
I had the same issue. Made a rule that every 3 hours stop polling. wait 30 secs, restart polling. Solved the problem.
I'll give that a try.
Be nice to know if there's a bug.
