I use the Z-wave poller for some older Linear switches to update the status. Recently one of these devices failed and I used the 'swap device' feature to replace the failed switch with a new Zooz switch.
I just noticed that I am getting a java error in my logs related to the polling app and it is attempting to poll the new device that replaced the original failed switch and then stops polling. However, the device name does not show up in the Z-wave Poller device list so I can't tell the app to not poll this device.
My assumption would be that Device 426 is a ZWave Plus and therefore doesn't have a Poll command. If that is the case the device needs to be removed from the polling app.
The device was/is called Hallway Light. The poller app is trying to poll device 426 which is the deivce id of the new device that replaced the old device.
