What do you guys recommend for z-wave plus plugs. I just need a simple on/off that’s reliable without lag?
I have the levinton plugs. I have 3 which have bad delays/lag. I’m starting to suspect the plugs and not the mesh. Plugs are anywhere between 3 feet to 10 feet away from the hub.
I have GE zwave+ in-wall receptacles, Leviton zwave in-wall receptacles, Leviton appliance outlets, Monoprice zwave+ outlets, and Dome zwave+ outlets. None of them show any lag. I used to have significant lag when I was using the zwave poller app.
All zwave PLUS wall powered devices should be about the same speed (at least on outlets, not as true on motion sensors - but those are typically battery powered anyway). They all use the exact same chip, so other than minor differences in programming, they are the same speed.
Interesting. I think I have one of those laying around. If I find it, I'll take a look.
Edit: Also, where specifically are you looking to see the update? Obviously dashboards update slower than device details, Which in turn update slower than watching the live logging....
Recommend, and often necessary. Zwave devices don't dynamically change their route table like zigbee does.
So moving a zwave device, and not doing a repair, does zero in terms of fixing routing issues UNLESS the device had the desired route in it's table already and the primary route isn't available due to the move.
