Z-wave Outlets do not report states anymore
I've noticed that all my Z-wave outlets suddenly stopped to report states. Seems to happen to all of them at about same time end of November, think may be related to 2.2.4 update. I can still control all of them. I did try to remove and add back, run z-wave repair, but still no state reported.
For just added back , no state at all.
All outlets are older z-wave GE model. No other z-wave device is affected.
Which device driver are you using?
Built in , Generic Z-wave outlet. I did try other drivers, like Generic Z-wave switch and few others. Same results, no state.
What hub are you using?
I'm on a C-3 and no issues here
I am on C-3 as well. I am missing state only if I remove and add device. For outlet that I did not remove, state just won't change. Sill can control and program status light. Did try hub soft reset, no difference. Unfortunately do not have 2.2.3 backups... To me it looks like something changed with z-wave with 2.2.4.
Were you using the poller app to get status for these? this will probably need to be setup again if you remove and then add back.
There is no state at all, events are empty even if I control from web interface. Logs are empty. But outlets do work.
Were you able to resolve this? I'm having a similar issue with a GE ZW4101... though my status changes in the WebUI if I control from there, it's just on-unit button press updates I'm missing.
No, I was not able to resolve. Pretty sure Hubitat firmware is the issue in my case.
If you hit refresh in web GUI, does status gets updated?
