Z-wave on C-7 breaks but comes online after shutdown
My Z-wave on my C-7 suddenly stops working after some time online. If I shut down the hub and turn it on again it works fine. But it then drops connection to all z-wave devices after a while...
After a shutdown and startup I have connection to ALL devices, but when I run a Z-wave repairit sais the nodes that worked after the restart are unreachable and the devices no longer work.
The z-wave firmware is up to date.
The Z-wave logs shows the following:
MarkisE2021-04-07 10:51:29.013 seqNo: 96, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
MarkisE2021-04-07 10:51:29.011 seqNo: 95, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
MarkisE2021-04-07 10:51:29.009 seqNo: 94, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
MarkisE2021-04-07 10:51:28.010 seqNo: 93, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
MarkisE2021-04-07 10:51:28.009 seqNo: 92, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
MarkisE2021-04-07 10:51:28.007 seqNo: 91, routeChanged: true, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Kælder2021-04-07 10:51:01.889 seqNo: 90, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Ventilation (trin)2021-04-07 10:50:54.256 seqNo: 89, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Ventilation (trin)2021-04-07 10:50:54.140 seqNo: 88, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Ventilation (trin)2021-04-07 10:50:52.316 seqNo: 87, routeChanged: false, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Ventilation (trin)2021-04-07 10:50:52.216 seqNo: 86, routeChanged: true, transmissionTime: 0ms, repeaters: None, speed: Unknown, rssi: [0 dBm, 0 dBm, 0 dBm, 0 dBm, 0 dBm], Ack channel: 0, Transmit channel: 0
Lys - Hønsehus2021-04-07 10:48:45.431 seqNo: 83, routeChanged: true, transmissionTime: 19ms, repeaters: [1c, 0e], speed: 9.6 kbs, rssi: [-81 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Lys - Hønsehus2021-04-07 10:48:45.331 seqNo: 83, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown
Ventilation (trin)2021-04-07 10:48:45.131 seqNo: 82, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-110 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Ventilation (trin)2021-04-07 10:48:45.129 seqNo: 81, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-110 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Ventilation (trin)2021-04-07 10:48:45.031 seqNo: 80, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 40 kbs, rssi: [-110 dBm, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
Any ideas?
Hi Henrik, Looks like you have some devices with a weak signal(the last 3 listed). You can try running a z-wave repair.
Please list your z-wave device brand/type and I'm sure some folks will jump in to help.
I noticed my z-wave is a little unstable at times, although it can be stable for a full week, but joining new devices can be hard to join and seem to create issues after. I've been joining devices slowly over a month to fully move over from my C4 to my C7
I solved it by deleting/excluding some z-wave devices that was not in use :slight_smile:
