If I chose the wrong forum, please excuse me.
I am trying to learn some z-wave products from other manufacturers into the Hubitat.
This also works partially, except for one special one.
ABUS z-wave multisensor
It is a certified z-wave plus product, should actually work in any z-wave gateway.
I've already tried out all the devices available in hubitat, but apart from the current temperature and air humidity I don't get any further information from the multisensor.
Question: What else can I try to use all functions?
Here are the technical possibilities:
Temperature Measuring range: 0 - 50 °C
Temperature Resolution: 0.1 °C
Temperature Accuracy: 1 °C
Humidity Measuring range: 0 - 100 %.
Humidity Resolution: 1%.
Humidity Accuracy: 5%.
Light sensor Measuring range: 0 - 65528 lx
Light sensor Measuring accuracy: 1 lx
Detection procedure: PIR: heat detection
Radio modulation: Z-Wave Plus ( S2 ) / FSK ( BFSK / GFSK )
Sensor type: PIR / thermometer / hygrometer / light sensor
Configuration options, e.g. of the transmission interval and sensitivity of the motion detector.
There is also a function overview of the individual configuration options (pages 12-14), but this is in German
Thank you very much.
Dirk
