So I have now installed that particular code. I see no error in the logs, however only on/off works. No other functions of the device (ie. VSP 1-4, on2/off2 etc...) seem to work. Update it does seem that the temperature reading of the pool works.****
Here are some logs.
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:30:22.565:debug<<<<< rspFlg=false dly:1500/1500 <<<<< Dev cmd: MultiInstanceCmdEncap(command:1, commandClass:32, instance:4, parameter:[null]) --> 6006200104NULL, 910005400102870301, 910005400101830101
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:30:22.547:trace----- setChanState command: MultiInstanceCmdEncap(command:1, commandClass:32, instance:4, parameter:[null])
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:30:22.495:trace+++++ setChanState(4, 255)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:26:02.242:debug<<<<< rspFlg=false dly:1500/1500 <<<<< Dev cmd: MultiInstanceCmdEncap(command:1, commandClass:32, instance:4, parameter:[null]) --> 6006200104NULL, 910005400102870301, 910005400101830101
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:26:02.229:trace----- setChanState command: MultiInstanceCmdEncap(command:1, commandClass:32, instance:4, parameter:[null])
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:26:02.198:trace+++++ setChanState(4, 0)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.948:debug<<<<< rspFlg=true dly:1500/1500 <<<<< Event: [name:airTempFreeze, value:81, unit:F, displayed:true, isStateChange:true] <<<<< Event: [name:airTempSolar, value:0, unit:F, displayed:true, isStateChange:true] <<<<< Event: [name:clock, value:14:28, displayed:false, descriptionText:PE653 Clock: 14:28]
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.897:warnCME: CAN'T FIND CHILD DEVICE: 38-ep6:poolSpaMode
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.894:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.891:debug+++++ createMultipleEvents( endpoint:6, name:poolSpaMode, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.889:warnCME: CAN'T FIND CHILD DEVICE: 38-ep10:swVSP4
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.886:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.883:debug+++++ createMultipleEvents( endpoint:10, name:swVSP4, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.881:warnCME: CAN'T FIND CHILD DEVICE: 38-ep9:swVSP3
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.878:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.876:debug+++++ createMultipleEvents( endpoint:9, name:swVSP3, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.873:warnCME: CAN'T FIND CHILD DEVICE: 38-ep8:swVSP2
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.871:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.868:debug+++++ createMultipleEvents( endpoint:8, name:swVSP2, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.865:warnCME: CAN'T FIND CHILD DEVICE: 38-ep7:swVSP1
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.863:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.859:debug+++++ createMultipleEvents( endpoint:7, name:swVSP1, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.856:warnCME: CAN'T FIND CHILD DEVICE: 38-ep5:switch5
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.853:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.850:debug+++++ createMultipleEvents( endpoint:5, name:switch5, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.847:warnCME: CAN'T FIND CHILD DEVICE: 38-ep4:switch4
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.845:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.836:debug+++++ createMultipleEvents( endpoint:4, name:switch4, externalParm:255, myParm:on)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.833:warnCME: CAN'T FIND CHILD DEVICE: 38-ep3:switch3
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.831:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.829:debug+++++ createMultipleEvents( endpoint:3, name:switch3, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.826:warnCME: CAN'T FIND CHILD DEVICE: 38-ep2:switch2
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.823:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.819:debug+++++ createMultipleEvents( endpoint:2, name:switch2, externalParm:0, myParm:off)
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.817:warnCME: CAN'T FIND CHILD DEVICE: 38-ep1:switch1
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.815:debugcreateMultipleEvents: devObj = null
[dev:257](http://192.168.7.201/logs#dev257)2018-10-09 07:24:59.803:debug+++++ createMultipleEvents( endpoint:1, name:switch1, externalParm:0, myParm:off)
