Z Wave motion sensors will not report motion
Hi guys
Im having problems were by 3 motion sensors(Z wave) I've tried will not report any motion. In all case I've tried both Insecure and secure join(I know Insecure Is preferred) . My location Is In the UK.
1st) Fibaro Motion Sensor FGMS-001 (V3.2)removed from ST.
I've reset this device and it paired with no problems, tried the stock driver and others I've found here. Other options will report ok like x,y,z but not the motion.
2nd) Fibaro Motion Sensor FGMS-001 brand new.
Same results as above
3rd) Aeotec Multisensor 6 brand new.
Pairs ok, correct stock driver loaded but still will not report motion.
I still have ST running but I've temporarily turned that off during some of my attempts and my Hue lights and bridge as well. The hub as been rebooted numerous times and tried In different rooms, also swapped around the z wave and zigbee radio sticks.
Im at a total loss now and would appreciate pointers.
Edit...
I have a Smartthings Motion sensor working fine(Zigbee)
Not really much help to you, but I have many Aeotec Multisensor 6s running the standard driver and they work fine including motion so it's not a device incompatibity issue.
I have 12 of the MultiSensor 6 working with this Custom driver:
I suggest you add that driver code and then try it. You don't have to use the driver forever, but if it works, you'll be closer to the solution you do want.
I'm usung the HE stock Fibaro Motion Sensor ZW5 and it's working OK.
