Never have any issues and nothing has changed, but a few weeks ago I noticed that nothing was working, found that the z-wave didn't seem to be responding so I shut downy hub. Powered back up and it's been fine. Then again today the same thing happens when I go home, did a reboot and worked for a few hours and it happens again. Just shut down and powered down for a few mins and I'm am back up again.
I can't fine anything in the logs that suggests the hubs going down or anything it's just stops reporting z-wave as if the chip has stolen working.
@bobbyD any ideas or anything within your logs that could help explain it.
I only have two battery powered devices. A window sensor, that I recharged yesterday just incase (it's never caused a issue before when it goes flat) and a fibaro motion sensor which is working. All other devices are mains powered or usb powered and are working.
Routes are all mostly direct with no route changes all good signals. Got 3 blinds which are connected S2 since day dot. Literally have not changed my networks for 2 years I suspect apart from firmware updates. It seems to fail each morning so I wonder if there is something new happening in the nightly clean up? Tempted to downgrade to early version of this release or previous.
I'll check the motion sensor later as although it's been working I haven't looked at it's battery and never replaced it.
Yes nothing changed for very long time, when I built my mesh when the C7 1st came out, I did it with a stick aswell ensuring solid joins before I moved on.
I don't really have any power reporting devices. The dimmers can but its all off.
Thought about this aswell but hubs running perfectly, ZigBee is perfect. It's just z-wave!? It's normally the last thing to go not the first.
Still none the wiser so far, maybe its going on strike because I'm planning on removing most of it (the aeotec motion sensors) and replacing them with ZigBee microwaves
So woke up and again nothing z-wave was running. This time I disabled z-wave and re enabled it. It brought everything back up for a bit.
So does anyone know the a way to send a signal to disable and enable this from RM maybe?
