Z-Wave Fibaro window/door sensor
So I have this device with a temperature probe connected.
The temperature stoped reporting 7 days ago. HE does not show the device as inactive and shows the device as Node 85.
When I do a Z-Wave repair, this device and some others are skipped. For instance, after the device finished node 84, HE logs Z-Wave repair complete.
All attempts to refresh etc... have not worked.
Here is the device info.. any thoughts?
Sounds like it’s dropped off the network.
Is it at the edge of you z-wave mesh?
Could the battery have gone flat?
I would bring it closer to the hub, exclude it properly and if the battery is good re join it.
Andy
