Z Wave fan switch not recognized
Just switched from ST to HE. So far, incredibly happy but I have a single Z-Wave switch that is causing me trouble. This GE Fan Controller worked fine with ST right up until I unplugged the ST Hub. However, I can't get it to include or exclude using HE.
I've successfully used the Hubitat interface to exclude each of my z-wave switches then re-include them into Hubitat. Except for this one switch - it doesn't even exclude.
I've tried pulling air gap but that didn't fix the problem. I've also rebooted my HE and no luck there either.
I don't think it's a range issue, because I have two other z-wave switches in the same gang box that are included in my hubitat network just fine.
Any other ideas?
David
Do you still have the ST hub? If so try doing an exclusion through it.
That did it! Thanks.
