I'm just getting started with my C8 Pro (running on 2.4.0.146), working on replacing my Wink setup (we all know why).
I started with moving a single GE Z-Wave Fan Controller and some light Lutron integration just to get things going, everything seemed kosher.
Today I added 4 more Fan Controllers, and things started going sideways. From what I can tell of the mesh, everything is well connected to the hub, no re-routes, no multi-hops, etc.
Manipulating a fan through the web interface seems stable enough, but when I try and manipulate the fan with the Android Web App, all hell breaks loose. The fan struggles, rapidly, switching between the current setting and the requested one. Sometimes it manages to find its way, sometimes it ends up staying where it was, and other times it gets stuck in waffle hell, rapidly switching between the two settings (low and medium, for example).
Looking at the live logs, and device events, it seems like the Mobile App may be spamming the living daylights out of the poor thing with set requests, multiple polls, etc. It's so bad that it can rapidly blow past the default 300 events for "too much".
Force stopping the app seems to consistently stop the behavior.
What is more odd, to me, is the Lutron integrated devices are manipulated just fine via the mobile app.
I've performed the shutdown/30sec unplug as detailed to reset the radio (even though I don't think this is a radio issue), with no change in behavior, I've also cleared the cache on the mobile app after killing it. I have not attempted to re-install the app (as of yet), but I suspect that won't yield anything different, either.
Below is a screen shot of the mesh setup, and a dump of the live logs during a couple of different freak-outs trying to adjust the fan with the mobile app. Any insight into what I may running up against would be much appreciated.
Trying to turn the fan off:
dev:82025-01-07 19:34:42.464infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:41.861infoBedroom 6 Fan is off [physical]
dev:82025-01-07 19:34:41.860infoBedroom 6 Fan button 2 was pushed
dev:82025-01-07 19:34:41.346infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:40.824infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:40.306infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:39.756infoBedroom 6 Fan is off [physical]
dev:82025-01-07 19:34:39.753infoBedroom 6 Fan button 2 was pushed
dev:82025-01-07 19:34:39.221infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:38.553infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:37.634infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:36.321infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:35.318infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:34.490infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:33.877infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:33.182infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:32.622infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:32.073infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:30.623infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:30.098infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:28.909infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:28.005infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:26.945infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:25.509infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:24.859infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:24.342infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:23.715infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:23.209infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:22.207infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:21.116infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:20.069infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:19.616infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:34:18.966infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:18.492infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:34:17.881infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:17.330infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:34:16.783infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:16.290infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:34:15.676infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:15.111infoBedroom 6 Fan was set to low [physical]
dev:82025-01-07 19:34:15.109infoBedroom 6 Fan button 1 was pushed
dev:82025-01-07 19:34:14.586infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:14.051infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:34:13.505infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:34:12.966infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:34:12.418infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:34:11.992infoBedroom 6 Fan was set to off [digital]
Trying to turn the fan back on to low:
dev:82025-01-07 19:37:57.376infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:56.438infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:55.160infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:54.608infoBedroom 6 Fan is low [physical]
dev:82025-01-07 19:37:54.605infoBedroom 6 Fan button 1 was pushed
dev:82025-01-07 19:37:54.080infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:53.564infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:52.689infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:52.160infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:51.055infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:50.390infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:49.421infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:48.893infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:47.796infoBedroom 6 Fan is low [digital]
dev:82025-01-07 19:37:47.281infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:37:45.570infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:37:45.056infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:37:44.014infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:43.488infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:42.956infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:37:42.410infoBedroom 6 Fan was set to low [digital]
dev:82025-01-07 19:37:41.892infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:41.363infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:40.268infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:39.557infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:36.940infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:36.304infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:35.785infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:35.280infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:34.765infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:34.224infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:33.686infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:33.118infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:32.074infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:31.027infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:29.885infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:29.350infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:28.846infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:28.308infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:27.783infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:27.241infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:26.479infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:24.985infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:23.938infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:22.825infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:21.737infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:21.178infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:20.654infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:20.132infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:19.557infoBedroom 6 Fan is off [physical]
dev:82025-01-07 19:37:19.555infoBedroom 6 Fan button 2 was pushed
dev:82025-01-07 19:37:19.029infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:18.422infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:15.796infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:15.239infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:14.712infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:14.174infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:13.658infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:13.144infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:12.559infoBedroom 6 Fan is off [physical]
dev:82025-01-07 19:37:12.557infoBedroom 6 Fan button 2 was pushed
dev:82025-01-07 19:37:12.037infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:11.340infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:08.742infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:08.210infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:07.700infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:07.190infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:06.645infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:06.055infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:05.004infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:04.487infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:03.945infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:03.422infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:02.887infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:02.324infoBedroom 6 Fan is off [physical]
dev:82025-01-07 19:37:02.322infoBedroom 6 Fan button 2 was pushed
dev:82025-01-07 19:37:01.796infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:37:00.834infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:59.108infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:58.508infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:57.550infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:57.010infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:56.460infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:55.945infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:55.390infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:54.769infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:53.843infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:53.329infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:52.683infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:52.165infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:51.636infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:50.661infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:50.104infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:49.494infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:48.482infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:46.245infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:45.228infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:44.720infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:44.186infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:43.658infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:43.110infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:42.563infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:42.038infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:41.110infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:40.455infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:39.929infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:38.912infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:38.392infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:37.416infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:36.715infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:35.629infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:34.028infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:33.438infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:32.434infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:31.887infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:31.370infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:30.866infoBedroom 6 Fan is off [digital]
dev:82025-01-07 19:36:30.264infoBedroom 6 Fan is off [physical]
dev:82025-01-07 19:36:30.262infoBedroom 6 Fan button 2 was pushed
dev:82025-01-07 19:36:29.752infoBedroom 6 Fan was set to off [digital]
dev:82025-01-07 19:36:29.072infoBedroom 6 Fan was set to low [digital]
