Z-wave Exclusion issues, with Inovelli Dimmer
I have a Red Series Dimmer that I am trying to exclude. It seems like this should be simple enough. I put the Hubitat into exclusion mode, then press the config button 3 times. After 30 seconds, they both time out but and the device is still in the list of devices and controllable by the hub. Am I missing something?
That is the correct method.. And I have done that several times myself..
Not sure why it's not working for you
I have only one Inovelli Red Dimmer, but I've moved it back and forth between at least two of my hubs using that method. Worked everytime for me.
I've found that sometimes the device needs to be very near the hub (or vice versa). It may be my system, don't know but you might try it.
This might be an indication of a repeating device on the route to the device that doesn't support NWI/NWE (Network Wide Inclusion / Exclusion)
Thank you ALL for the responses so far!
So I have a couple more things I can add.
  • It appears that this is only happening to my Dimmers. I was able to exclude an Inovelli Black Switch and another Z-wave device. Very easily! YA! Rules to fix.
  • I've tried to exclude two additional Red Series Dimmers, One that I just installed yesterday (Original FW) and the other I have previously excluded in order to update the FW. Both failed to be excluded.
  • If I hang out at the dimmers and wait for the exclusion process to time out, The dimmers LEDs flash red... Guessing that's the dimmer letting me know that the exclusion failed...
  • As I expected, moving the hub closer (within 4') didn't change anything. I have been able to do this several times before without issue.
So at this point, what are the implications of forcibly removing the two dimmers and performing a factory reset on them? I "thought" I read somewhere in this forum that this isn't a good practice to do?
Not much..
I actually do this more often than I will admit because I forget to exclude when I disconnect a hardwired device.. and too lazy to wire it back up for exclusion..
LOL! Then the immediate problem is resolved :slight_smile:
Because I try to advocate doing things the right way.. I just don't follow my own instructions some times..
I hear you! I always try to do it the right way the first time as well.
Thanks for the feedback!
anytime
