Hello, I posted a similar topic back in September, but that time a simple unplug-replug solved the issue but this time it did not. None of my z-wave devices are controllable. If I go to the logs I can see that their status is updating (on/off/level/etc.) but if I turn them on or off within hubitat nothing happens. When I do a z-wave repair they all appear as unresponsive.
I am on version 2.2.4.153 although this issue started before I updated, I just hoped the update would fix the issue and I am using a Rev C-7 Hub.
I tested with google as well and I have the same issue. If you look in your logs are you still getting reports from the devices? Very strange that the devices are communicating with the hub but not getting commands from the hub.
I will check when I get back home. The weird part is that I reverted to the previous version thinking that would undo some sort of error. But it did not.
I wasn't aware of the other update. Maybe I will roll further back and see what happens.
I spent the past day writing a rather complex motion lighting rule. Finally got it working, and celebrated with a nice BBQ. Updated the hubitat and everything is now offline. Now the celebration is over. Hahahaha
Interesting, and just a quick update from my end. @danabw stated in This Post that a reboot is necessary after the .156 update but that did not fix my issue. I am now trying a hard reboot (unplug for 5 minutes). I'll report back shortly.
