Does anyone have any tips for updating the firmware on Z-Wave switches? I did one and it worked fine, but now I've got one (Inovelli Red Dimmer, same as the first one I did update successfully) that just won't take. It gets to like 60% and then throws an error.
Device Firmware Updater: ERROR: The device was unable to receive the requested firmware data
I've air-gapped the switch multiple times trying to get it to work and can't get anything to work. I am using the Device Updater App.
This one is in the basement and the hub it pretty much right above it, so I wouldn't think it's a distance issue, but maybe it is?
Just looking for some tips/tricks to make this a bit easier and more robust. I don't really want to move the main hub all over the place, but was wondering if maybe getting another hub I can mesh to and take that around to update firmware?
I am hoping there are other tips though that don't involve buying another hub.
Thanks for any advice you can give!
