Since upgrading to 2.2, my hub is much faster. I also noticed under z-wave details that my node ID's have changed from dec(hex) to hex only.
Did you happen to see the same thing?
I thought I was crazy , so I restored the last version and confirmed the display changed.
Not having the dec makes it harder to coordinate with pc-controller. Yes i know I can convert, but having both was better, me thinks.
This just happened. I agree it makes comparing info from inside Hubitat with other tools take one additional step.
@chuck.schwer Can we get the hold dec(hex) listing of the node IDs back? Or if you want you can put the decimal value in parenthesis.
Did you check if the zwave repair still using decimal? I don't want to update yet. Thanks.
Z-Wave repair in the logs still shows the decimal values.
Thanks, that's what I meant. Worse to understand now a zwave repair vs the details page
