Z-Wave database totally hosed
Ever since I upgraded to the C8 I believe I have been having issues with database corruption. I even did a soft reset and a restore and the Z-Wave issues continue to occur. I clearly have ghost devices present but the problem is they do not show up anywhere in the Z-Wave Details screen, in the topology, in the Devices list. They are complete ghosts, and the logs show stuff like this constantly. dev0 does not exist. There is also a dev device which also does not exist.
There is another symptom; when I try to exclude a device, the hub prompts that a device by another name was excluded. Clearly a data corruption problem.
I would appreciate some advice from Hubitat support on how to address this issue because nothing I have tried works. Is there a way to completely wipe out the zwave database, reset all my devices and start from scratch?
dev:02024-06-30 02:32:57.016 AMinfoseqNo: 125, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown, rssi: [N/A, N/A, N/A, N/A, N/A], Ack channel: 1, Transmit channel: 1
dev:02024-06-30 02:32:52.908 AMinfoseqNo: 125, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown
dev:02024-06-30 02:32:52.703 AMinfoseqNo: 124, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown, rssi: [N/A, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 1
dev:02024-06-30 02:32:48.495 AMinfoseqNo: 124, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown
dev:02024-06-30 02:30:27.485 AMinfoseqNo: 118, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown
dev:02024-06-30 02:30:23.260 AMinfoseqNo: 118, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: Unknown
When you exclude a node, the name shown would be the same one that shows on your Z-wave details page.
It almost sounds like you made changes to your z-wave devices and then afterwards restored and older backup. Leaving some device paired to the mesh but the hub no longer has them in the z-wave table. Is that possible?
It's not the same name.
