I wanted to put out a quick update to those who have been offering their tips and suggestions, First, thank you all for your help. The awesome people in this community and their willingness to step in and help others is REALLY what sets Hubitat apart. I jumped whole hog from ST about two or three years ago. I find myself trying to do far more than I ever even thought about trying with ST.
So, it appears I have several things that kinda bubbled to the Surface about the same time.
I'm sure it all started when I placed my hubs on a metal shelf. That has been fixed now.
I have excluded all of the illumin bulbs from the hub, and reset them all (except two that are being particularly stubborn).
I went to Inovelli's support page and got the driver code from there rather than using the code in Hubitat (I thought it was the same, maybe I was wrong),
After adding the code I then included two of the bulbs back into the system and was able to update the firmware on both at that point.
Since then they have been working nearly flawlessly. I still have two bulbs that I can't seem to get to exclude, Once I get the UBZ-7 ill work on getting them and any other orphan devices out.
If I'm successful in excluding them, i'll reset them, then add them back with the new code, and finally update their firmware.
That firmware update to 2.31 really makes a difference in bulb responsiveness etc so anyone who has had trouble with Ilumin bulbs and is on bulb fw 2.29 (or lower!) should update it asap. Also with 2.31 you can now pair with no security instead of forced S0 by quickly turning the bulb on / off 3 times when pairing. Again as with all powered Z-Wave devices you must leave the power on at all times!!!
Both these units get reviewed well on Amazon. I have the Eaton one. But I know that others here have the Siemens unit. They can both be installed indoors or outdoors.
This is what I got based on recommendations in the forum. Problem with all of these is you quickly know if they didnβt work, but itβs impossible to tell if they work because nothing blows.
What driver are you using with this bulb? I have some older GoControl Z-wave bulbs and the generic drivers and existing z-wave drivers for other bulbs I have found through Hubitat don't seem to control it.
