Z-Wave associationGet for Group > 1 Not Working
I'm having some interesting results with Z-Wave associations. Setting an association seems to work great. Getting an association report for anything over group 1 isn't quite working right. For example, if I send the following:
cmds << zwave.associationV2.associationGet(groupingIdentifier:1)
cmds << zwave.associationV2.associationGet(groupingIdentifier:2)
cmds << zwave.associationV2.associationGet(groupingIdentifier:3)
I get:
AssociationReport(groupingIdentifier:null, maxNodesSupported:null, reportsToFollow:null, nodeId:null)
AssociationReport(groupingIdentifier:1, maxNodesSupported:5, reportsToFollow:0, nodeId:1)
Seems like a small bug. Hoping it can get fixed. :slight_smile:
Thanks, we'll have a look!
@ericm
I reviewed our association report implementation and its not obvious why it's doing this.
Can you post the data coming into parse that's causing the null reports?
Here you go. Raw description for the 1st group (which comes in ok). Then the raw description for the failed groups.
Parsed AssociationReport(groupingIdentifier:null, maxNodesSupported:null, reportsToFollow:null, nodeId:null) to [null]
Associations for Group null: []
zw device: 4C, command: 8503, payload: 03 05 00
zw device: 4C, command: 8503, payload: 02 05 00
Parsed AssociationReport(groupingIdentifier:1, maxNodesSupported:5, reportsToFollow:0, nodeId:1) to [null]
Associations for Group 1: [01]
zw device: 4C, command: 8503, payload: 01 05 00 01
this will be fixed in the next release, or rather it is fixed, and will be available in the next release LOL
That is awesome. Thank you so much. I have a similar issue with the protection command class. I debated messaging about it here, but since it has similar results, maybe it will get fixed too with this update.
So first setting protection doesn't seem to work:
zwave.protectionV2.protectionSet(localProtectionState : 2, rfProtectionState: 0)
Getting the protection report returns the same null info as mentioned above:
zwave.protectionV2.protectionGet()
Returns:
ProtectionReport(localProtectionState:null, rfProtectionState:null)
'zw device: 4D, command: 7503, payload: 00 02 ' parsed to null
Anyway, this one is low priority, but just wanted to make you aware in case it is related to this association problem.
Thanks for everything!
It isn't, I mean each one of these is a separate method, so the problems with them are specific to the command
If you can batch these up it's easier for me to track and fix, i need to get out of current mode whatever that is and enter zwave mode if you follow.
