Looks like that code has to go on the device.
Its going to be easiest if you bind something useful to the main endpoint.
The easiest would probably be multilevel switch (dimmer). Then you could use a generic dimmer driver with it. To simulate blinds you could create a virtual blinds device and mirror the level to it with a rule or other app.
Actually... since Hubitat did not support the Windowshade class until recently my ZEN53 driver will pick up multilevel and then treat the device like blinds. The way the driver is made it can be used a generic blinds driver as well, just dont use the calibration commands. [DRIVER] Zooz ZEN53 DC Motor Controller (for shades)
I wonder what reports the device sends when you use ZUNO_BLINDS_CHANNEL_NUMBER (from zunoAddChannel)
*Dang this thing looks really complicated just to control some blinds! Are you just connecting this to one motor? ZEN53 would have been plug and play.
