YoLink Water Meter
Continuing the discussion from [RELEASE - BETA] - "YoLink™ Device Service" app and drivers to connect Hubitat™ to YoLink™ devices:
Below is the error message I get : (see below)
Processing Complete
The installation returned the following error(s):
YoLink Device Service Installation Errors - Created 08/21/2024 10:28:40 PM YoLink Device Service App Version 2.1.18 Hubitat information: Hardware=000D Firmware=2.3.9.166 Uptime=186452 ----------------------------------------------------------------------------------------------------------------------------------------------- An error occcurred while trying to add child device 'YoLink WaterMeterController - YoLink WaterMeterController' Unable to create device 'YoLink WaterMeterController' because driver 'YoLink WaterMeterController Device' is not installed. Either the device is not currently supported by the YoLink Device Service app or you need to install the driver using the 'Modify' option in the 'Hubitat Package Manager' app.
View the error file at YoLink_Service_Errors.txt
First off, your YoLink integration for Hubitat is fantastic. It seems to work perfectly on all of my temp and humidity sensors and I'm sure will work equally well on other items I'll add in the future.
I have two YS5008-25 YoLink FlowSmart All-in-One water meters with shutoff valve and would love to see them supported on Hubitat.
YoLink FlowSmart All-in-One Smart Water Management System: 1" Ultrason.
Depending on what is required, I may be able to pull logs to help with the driver development. These are a site that I don't normally have my PC at, so my turnaround time may be less than timely.
Here is the error log when I run the Yolink installation.
settings
Processing Complete
YoLink Device Service Installation Errors - Created 01/27/2025 04:54:16 PM
YoLink Device Service App Version 2.1.19
Hubitat information: Hardware=000D Firmware=2.4.0.151 Uptime=460
An error occcurred while trying to add child device 'YoLink WaterMeterController - YoLink Water Meter 1'
Unable to create device 'YoLink Water Meter 1' because driver 'YoLink WaterMeterController Device' is not installed.
Hubitat information: Hardware=000D Firmware=2.4.0.151 Uptime=461
