Hubitat app and drivers for the YoLink Local Hub. Talks to the hub over the LAN - no cloud account, no internet dependency. State arrives over MQTT as it changes, with a periodic HTTP poll as a backstop.
github: inindev/hubitat/tree/main/yolink_local_hub
(as a new forum user it wont let me give the github link)
This requires the YoLink Local Hub specifically - the model with local API support - with the local API enabled in the YoLink app. It does not work with the standard YoLink hub, which is cloud only.
Supported: door/contact, temperature-humidity, leak, outlet/switch, power failure alarm, and garage door controllers.
YoLink garage controller support: Pair it with a tilt sensor, either a YoLink one or any Hubitat tilt sensor you already have. Without one, the button works but position stays unknown.
Setup, credentials, and the garage details are in the README.
