Yet another Virtual Thermostat Driver
The thermostat in my house died. Thought I might replace it with a dry relay, for heating only at the moment, and leverage the, Hubitat-supplied, Virtual Thermostat driver as an experiment. The results were not good. My heater very quickly ran away.
I looked at the example driver in the Hubitat repository on github and, if the driver I was testing is anything like that code, got a pretty good idea as to the cause(s).
Copied the Hubitat driver, refactored, and fixed what I could without getting weird. Installed and tested, for a couple of weeks now, without significant issues.
With this post, I am hoping others might review/comment/suggest if you have the time and inclination?
Interface differences:
Removed some strange public methods that could alter internal, what should be derived, state. Notably, thermostatOperatingState. UI functionally is otherwise the same.
Added interface/semantic:
Short-cycle protection. Didn't want to expose the user to the concept of duty-cycle or warn against potential equipment damage (compressors!) if not correctly configured and enforced. I chose to expose an enforced "minimum idle time" in the settings page, and gave it a default of 10 minutes. Seems to accomplish the goals without imposing the technical considerations on the user. UI is not a strong point for me, so is my choice appropriate, or at least good enough?
Testing:
It's been running for a couple of weeks without functional problems. There was one small bug where it would not switch from pending to idle when the user aborted the cycle, by changing the set-point back to what should have caused a purely idle state. Functionally, the operation was correct, but no event was generated that would tell other apps it was no longer pending. That little fix was only made very recently.
I wrote a little "bonder" application to forward temperature sensor events from an "Aeon Multisensor 6", and reflect operating state events from the driver to a "Generic Zigbee Multi-Endpoint Switch".
Apparently, these forums do not allow URLs? The code described lives on github, my username is "hlward", under the project "hubitat". That should be enough to find it, no?
[Edit: With my new, wonderful, "owner" membership I can post URLs!]
The code may be found at hubitat/virtualThermostat.groovy at main · hlward/hubitat · GitHub
Without the ability to point you at it, trivially, it seems appropriate but sub-optimal to just include it in this message. So....
/* vim: set et ts=4 sw=4: */
    Virtual Thermostat
    Copyright 2016 -> 2023 Hubitat Inc.  All Rights Reserved
    Copyright 2023 Lee Ward with No Rights Reserved
    Lee Ward, LICENCE:
    My changes are placed in the public domain. Any person or entity may, at
    their discretion, remove my copyright notice, my statement(s) of
    attribution, etc.
    Lee Ward, re. Warranty:
    No warranties of any kind are provided, expressed or implied.
metadata {
    definition (
        name: "Virtual Thermostat",
        namespace: "tochtli",
        author: "Kevin L., Mike M., Bruce R., Lee W."
        capability "Actuator"
        capability "Sensor"
        capability "Temperature Measurement"
        capability "Thermostat"
        // Commands needed to change state/attributes of virtual device.
        command "setTemperature", ["NUMBER"]
    preferences {
        input( name: "hysteresis", type: "enum", title: "Thermostat hysteresis", options: ["0.1","0.25","0.5","1","2"], description: "", defaultValue: 0.5)
        input( name: "idleWait", type: "number", title: "Idle time minimum, in seconds", defaultValue: 300)
        input( name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: false)
        input( name: "txtEnable", type:"bool", title: "Enable descriptionText logging", defaultValue: true)
import groovy.json.JsonOutput
import java.time.Instant
def installed() {
    log.info "installed..."
    initialize()
def updated() {
    log.info "updated..."
    log.info "debug logging is: ${logEnable == true}"
    if (idleWait < 0)
        device.updateSetting("idleWait", [value: "0", type: "number"])
    unschedule()
    if (logEnable)
        runIn(1800, logsOff)
    // Recalculate the operating state.
    sendEvents ChooseNextOperatingState()
def initialize() {
    log.info "initializing..."
    if (state?.current != null)
        return
    // We maintain an internal copy of critical state attributes, and work from/with them, since
    // our updates are asynchronous and we often must alter multiple attributes in
    // a transaction.
    // The strategy, then, is to perform changes of state and, only after, reflect those
    // changes by publication.
    // Assume a reasonable state using the following defaults...
    state.current = [:]
    state.current.mode = "off"
    state.current.temperature = convertTemperatureIfNeeded(68.0, "F", 1).toFloat()
    state.current.heatingSetpoint = state.current.temperature
    state.current.coolingSetpoint = convertTemperatureIfNeeded(75.0, "F" ,1).toFloat()
    state.operatingState = "idle"
    state.lastIdle = Instant.EPOCH.toString()
    // Publish that state.
    def text = "initial value"
    def events = []
    events << [name:"thermostatMode", value:"${state.current.mode}", descriptionText:text]
    events << [name:"temperature", value:"${state.current.temperature}", descriptionText:text]
    events << [name:"thermostatSetpoint", value:"${state.current.heatingSetpoint}", descriptionText:text]
    events << [name:"heatingSetpoint", value:"${state.current.heatingSetpoint}", descriptionText:text]
    events << [name:"coolingSetpoint", value:"${state.current.coolingSetpoint}", descriptionText:text]
    events << [name:"thermostatOperatingState", value:"${state.operatingState}", descriptionText:text]
    events << [name:"thermostatFanMode", value:"auto", descriptionText:text]
    //events << [name:"setSupportedThermostatFanModes", value:JsonOutput.toJson(["auto","circulate","on"]), descriptionText:text]
    //events << [name:"setSupportedThermostatModes", value:JsonOutput.toJson(["auto", "cool", "emergency heat", "heat", "off"]), descriptionText:text]
    sendEvents events
def logsOff() {
    log.info "debug logging disabled..."
    device.updateSetting("logEnable", [value:"false", type:"bool"])
def setTemperature(temperature) {
    if (temperature == null) {
        log.warn "null temperature update ignored"
        return
    state.current.temperature = Float.parseFloat("${temperature}")
    def events = []
    def u = "°${getTemperatureScale()}"
    events << [
        unit:"${u}",
        descriptionText:"temperature set to ${state.current.temperature}${u}"
    finalize events
def auto() { setThermostatMode("auto") }
def cool() { setThermostatMode("cool") }
def emergencyHeat() { setThermostatMode("emergency heat") }
def heat() { setThermostatMode("heat") }
def off() { setThermostatMode("off") }
def setThermostatMode(mode) {
    if (!(mode in ["off", "auto", "cool", "heat", "emergency heat"])) {
        log.warn "Unknown mode, ${mode}, ignored"
        return
    if (mode == "emergency heat") {
        // We don't support an emergency backup heater, so...
        mode = "heat"
    state.current.mode = mode
    def events = []
    events << [name:"thermostatMode", value:state.current.mode]
    finalize events
def fanAuto() { setThermostatFanMode("auto") }
def fanCirculate() { setThermostatFanMode("circulate") }
def fanOn() { setThermostatFanMode("on") }
def setThermostatFanMode(fanMode) {
    if (!(fanMode in ["auto", "circulate", "on"])) {
        log.warn "unknown fan-mode, ${fanMode}, ignored"
        return
    def events = []
    events << [name:"thermostatFanMode", value:fanMode]
    sendEvents events
def setCoolingSetpoint(setpoint) {
    if (setpoint == null) {
        log.warn "null cooling set-point update ignored"
        return
    setpoint = Float.parseFloat("${setpoint}")
        def events = []
        Float x = setpoint - 2 * Float.parseFloat(hysteresis)
        if (state.current.heatingSetpoint > x) {
            state.current.heatingSetpoint = x
            events << [name:"heatingSetpoint", value:"${state.current.heatingSetpoint}"]
    finalizeSetSetpoint(events, "coolingSetpoint", setpoint)
def setHeatingSetpoint(setpoint) {
        log.warn "null heating set-point update ignored"
        return
        def events = []
        Float x = setpoint + 2 * Float.parseFloat(hysteresis)
        if (state.current.coolingSetpoint < x) {
            state.current.coolingSetpoint = x
            events << [name:"coolingSetpoint", value:"${state.current.coolingSetpoint}"]
    finalizeSetSetpoint(events, "heatingSetpoint", setpoint)
private finalizeSetSetpoint(events, String k, Float v) {
    state.current[k] = v
    events << [name:"thermostatSetpoint", value:"${v}"]
    events << [name:k, value:"${v}"]
    finalize events
def setSchedule(schedule) {
    if (schedule == null) {
        log.warn "null schedule update ignored"
        return
    def events = []
    events << [name:"schedule", value:"${schedule}"]
    sendEvents events
    log.err "$description"
private logDebug(msg) {
    if (settings.logEnable) log.debug "${msg}"
// Choose an operating state and send all events; The given events list is value-result.
private finalize(events) {
    events.addAll ChooseNextOperatingState()
    sendEvents events
// Send the given events in order.
private sendEvents(events) {
    for (event in events) {
        // Capture or create descriptive text.
        def descriptionText = event?.descriptionText ?: "${event.name} set to ${event.value}"
        logDebug descriptionText
        // Strip descriptive text from this event.
        Map e = event.findAll {it -> it.key != "descriptionText"}
        if (settings.txtEnable) {
            // Add/Restore descriptive text to this event.
            e.descriptionText = descriptionText
        sendEvent e
// Perform actions based on the current state and return a list of events reflecting those actions.
private ChooseNextOperatingState() {
    def h = Float.parseFloat(hysteresis)
    def nxtOperatingState = "idle"
    switch (state.current.mode) {
        case "auto":
            if (state.current.coolingSetpoint <= state.current.heatingSetpoint) {
                // Out of order event delivery? Race? Doesn't matter. Nothing we can really do about it. Hope
                // another set-point-set comes along to make them consistent soon!
                log.err "inconsistent set-points -- unable to determine new state"
                return []
            if (state.operatingState == "idle")
                h = 0
            if (state.current.temperature < state.current.heatingSetpoint + h)
                nxtOperatingState = "heating"
            else if (state.current.temperature > state.current.coolingSetpoint - h)
                nxtOperatingState = "cooling"
            break
        case "cool":
            if (state.operatingState == "cooling")
                h = -h
            if (state.current.temperature >= state.current.coolingSetpoint + h)
            break
        case "heat":
            if (state.operatingState != "heating")
            h = -h
            if (state.current.temperature <= state.current.heatingSetpoint + h)
            break
        default: // off
            break
    // Avoid short-cycling by forcing a transition through the idle state, if needed.
    if (nxtOperatingState != state.operatingState && !(state.operatingState == "idle" || nxtOperatingState == "idle"))
        toOperatingState("idle") // Internal state change; Discard the events, then.
    return toOperatingState(nxtOperatingState)
// Perform actions needed to achieve the given, desired, operating state and return a list of
// events reflecting those actions.
private toOperatingState(String nxtOperatingState) {
    def ttxt = "${state.operatingState} -> ${nxtOperatingState}"
    logDebug ttxt
    def events = []
    if (nxtOperatingState == state.operatingState) {
        if (nxtOperatingState != "idle" || device.currentValue("thermostatOperatingState") == "idle") {
            // Nothing to do -- Short out
            return []
        // Here only if all we need to accomplish is to remove a "pending" notice.
    } else if (nxtOperatingState == "idle") {
        // Transitioning into the "idle" state.
        state.lastIdle = Instant.now().toString()
    } else if (state.operatingState == "idle") {
        // Transitioning away from "idle" but must honor the required wait-time.
        Instant timeout = Instant.parse(state.lastIdle).plusSeconds(idleWait)
        Instant now = Instant.now()
        if (now.isBefore(timeout)) {
            // Start/Restart the idle timeout wait handler.
            long nSec = timeout.getEpochSecond() - now.getEpochSecond() + 1
            logDebug "delay ${ttxt}, idle wait; Retry in ${nSec}"
            runIn(nSec, idleTimeoutHandler)
            // Just need to publish what we wanted to do, but couldn't yet. Set that up and short out.
            def Map m = ["heating":"pending heat", "cooling":"pending cool"]
            events << [name:"thermostatOperatingState", value:m[nxtOperatingState]]
            return events
    state.operatingState = nxtOperatingState
    events << [name:"thermostatOperatingState", value:state.operatingState]
    return events
def idleTimeoutHandler() {
    logDebug "idle timeout!"
Thank you for your consideration and, in advance, for comments or suggestions.
Edit your message using Screenshot 2023-02-08 at 10.28.23 AM, then Select all that code and then click: Screenshot 2023-02-08 at 10.26.57 AM
I cannot find the pencil icon anywhere on the page? Well, other than your suggestion of course. The title bar for the page at the top indicates I am still logged in. Perhaps some setting I have to make to enable editing my own posts?
At the bottom of your original post.
Screen Shot 2023-02-08 at 12.57.59
Not present for me. I have only 3 controls there:
  • share link
  • bookmark post
  • compose a reply
at the end of your original post, it looks like this to ME...
Your message for ME, has nothing between the heart, link and ... icons, but YOU should have the pencil and trash. (like mine does in the reply.)
For Topics that I have created, this is what I see:
which includes the pencil and trash.
Then, it looks the same for both of us. I tried to take a screenshot but I am not allowed to include "media items" in my reply to you.
Join the owners group. It will give you permission to edit your posts, send PMs, and include images in messages. I've linked to it below:
https://community.hubitat.com/g/owners
Done. Edited per @csteele suggestion. Thank you for your patience and help.
