Yet another couple of migration questions.... C7 -> C8 Pro
Upgrading from C7 to C8Pro. (will include Zwave, Zigbee, webcore)
Have been reading through the documentation, and:
-Have made a list of all of my cloud apps and devices that will need to be disabled (check)
-Have made a way to easily update the cloud shortcuts in Tasker using a global variable for the Hub ID (check)
Those were easy. Now for the questions
1-Webcore Pistons: Using the built in webcore (not the HPM version) Do I need to disable the individal pistons? Or just the Webcore app in automations?
2-Looking at the back up/restore database instructions, it mentions to verify that you have "migration ready" backups in your cloud backup section. I have Hub Protect, and several that show in the ALL or Just this hub section. They all have checks in the Zwave and Zigbee columns. HOWEVER, when I change to view "migration ready," there are none. Is that something that would only show when I boot up and log into the new hub? Am I good?
3-File this question under the Silly category (maybe)... Hub names. If I want to use the same name "home" on my new hub as I was using on my old one, does that automatically carry over from the DB restore? Or, should I name the C7 one OldHome first just to not get them confused on the registered hub page?
Not 100% on this, but I believe the migration ready backups are for users that are eligible for a cloud backup/restore as part of their hardware upgrade but don’t also have hub protect.
As long as your cloud backup includes both radios, it should be effectively migration-ready.
This is correct. I bricked the z-wave radio of a C-8 Pro sometime last year. And used a cloud backup to get another C-8 Pro up and running within minutes.
Yep, I pulled the trigger earlier this morning.
The only thing giving me issues is the Google SDMI app. Reauthorized fine. Just not getting any events back. On over to that forum thread.....
And done..... Found the fix for it that I had forgotten to write down.
This has been the source of great confusion for some users. There is no difference between a "migration ready" backup and a cloud backup, other than the fact that "migration ready" backups are cloud backups from different hubs. Next update will retire the term "migration ready" to reduce confusion. Thanks for all your feedback!
To be fair, I read everything with multiple points of view just so that I do not assume "my" view is the correct one.... (casualty of my job.... or what makes me good at it..... chicken and egg thing). In any case, whenever there is a possible view other than mine, I tend to ask for clarification.
Opened a support ticket, had also sent an email but didn't get any response. My hub's Zigbee radio is showing offline. It had happened a few years ago and I think support helped me to get it back online. This time I have tried. enable/disable. Power cycle, reboot etc but nothing helped. I bought a replacement hub but I am unable to get the backup. Its failing with error ;
Backup failed, incomplete tasks: Zigbee backup, database backup, Z-Wave backup, file manager backup, backup upload.
Can you please help.
Tx.
