I have a yeelight bulb using the built in driver that doesn't work since I updated to the 2.3.113 update. (Didn't work on 112 either, but those are the only two I had for 2.3). Was working on 2.2.9.x. I tried removing the device and app and reinstalling them, no luck.
Error in logs: errorjava.lang.NullPointerException: Cannot invoke method getAt() on null object on line 133 (method parse)
Anyone else seeing this? Any idea how to get it working again?
I have not, I worry about rules when I go backwards . I also only have one yeelight, and I just replaced it with a zigbee bulb temporarily while it's looked at. Seemed easier than trying to rollback
I haven’t had any issues moving back and forward. That said, I have an unused hub that I can try a lot of these things with, so probably not as much of a risk for me.
Hopefully someone else who has a Yeelight can chime in.
My 6 Yeelight bulbs are working fine in 2.3.0, even throughout beta. Try unplugging or cutting power then back on to the device with the Yeelight on it and give it 5 mins to see if it works again on your Hubitat hub.
That's how I fix it if my Yeelight bulbs don't work on my Hubitat hub although that's usually rare to drop off for me.
