Yeelight, Nanoleaf etc
the current integration says it installs it, but it's lying to you...
this is just a logging issue that was also fixed.
This integration looks at the model number returned by the device to figure out which driver to allocate, so users are going to have to tell me which models aren't supported so i can add them to the integration, the integration in 2.0.6 also logs the submitted model to the live logs for me to include in the next release, which should make this easier to update.
There isn't any way to manually include a device, nor force install one.
The good news is that I can indeed control the lamp. I hope the strip eventually reappears.
The light says "SmartLED Bulb Color YLDP06YL
The Strip is YLD02YL
How do you get the strip to be picked up by the Yeelights app?
Did you activate the LAN control on the Yeelight app?
I finally found it in the app. whew.
Is there any other way to set these up than with the iOS app? Every time I click on something, the lights drop into a motion routine.
