Yeelight integration dashboard tiles
Hello!
I have found some unused Yeelight bulbs (1S color and 1SE color type) and have added them to hubitat, unfortunateli the tiles does not work, however grup of devices does work. Also device control page works, and Adaptive Lightening app and Day Lights work. They have been given Yeelight RGBW Bulb driver for Adaptive Lightening could see them. Tiles in EZ dashboard and Hubitat Dashboard does not work. Also icon is wrong, I have had to change it to custom. Look at the picture please.
Is it bug? As I mentioned the workaround is using grouping, but that is not the solution to the problem.
When you look at the device page -> current states, do you see values for hue, saturation, color, and level? I have a few Yeelight bulbs and mine look like this:
If any states are missing, try using the commands tab to set the missing values. I haven't had your exact issue, but I had some Sengled Zigbee bulbs that would silently fail to show up in Google Home because of missing attributes, and sending commands to the bulb with a value for each attribute fixed the issue.
I have all of these current states.
I do not know how and why, but the problem is gone. It repaired by itself. :thinking:
