Can't change Color temperature and Level any more.
Yeelight CT driver.
Hi - has anything changed since you last could update? What Hub platform version are you on?
Could you confirm you are using the Hubitat driver and not a community one?
I am using Hubitat driver, was not even aware that community driver exists.
My hub is C7 with latest firmware.
There are quite a few community drivers, most are public, but some users don’t publish theirs. I am not sure if there are or not for Yeelight…
This is a Wifi device, right? Are you able to change the temp and level from the app (assuming there is one…)?
I assume that the other commands for it work from Hubitat (on/off)?
Tagging @support since this is a built-in driver.
On/off work fine. Only level and color temp do not. But if I change level or color temp in app, Hubitat will reflect changes.
Interesting, thanks! It probably won’t make a difference, but what happens if you reboot your Hubitat hub?
Reboot makes no difference.
