Yale Zigbee lock constantly sending battery update
Moved over my last Zigbee device. My Yale YRD210 Zigbee lock. Pairing went quick and code setting (names) was easy. Only one odd thing. It's constantly now sending it's battery information...as in every second. The zigbee log just ticks by every few seconds with an update from the lock. I don't ever remember this from on ST but can't say I ever looked either.
Can't imagine this is good for the battery
Normal?
dev:2282018-10-29 20:32:42.645:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:41.637:infoGarage Door Yale Deadbolt Lock battery is 72%
dev:2282018-10-29 20:32:40.634:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:39.625:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:38.631:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:37.622:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:36.613:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:35.602:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:34.605:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:33.608:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:32.597:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:31.582:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:30.596:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:29.576:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:28.632:infoGarage Door Yale Deadbolt Lock battery is 71%
dev:2282018-10-29 20:32:27.571:infoGarage Door Yale Deadbolt Lock battery is 71%
No, it's a bug, it's fixed and will be out in the next release, which will be out very shortly.
You will need to click configure in the driver after the update.
Still doing it. Upated HUB and then went into lock device and hit configure. It downloaded all 255 codes! But still getting:
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:57.938:infoGarage Door Yale Deadbolt Lock battery is 64%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:56.937:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:55.920:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:54.927:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:53.923:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:52.917:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:51.916:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:50.910:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:49.909:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:48.904:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:47.902:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:46.898:infoGarage Door Yale Deadbolt Lock battery is 65%
[dev:228](http://192.168.13.46/logs#dev228)2018-10-31 00:45:45.886:infoGarage Door Yale Deadbolt Lock battery is 65%
Try pairing the lock again
After that it is not longer constantly sending battery updates. At first I thought it was but the new update must also run through and get ALL the lock codes so it had a lot of chatter as it was getting all 250 codes.
If anyone is interested this seems to be a smoking good deal on a yale lock.
https://www.mydigitaldiscount.com/yale-real-living-keyless-push-button-deadbolt-lock-with-zigbee-wireless-polished-brass-yrd210-ha-605/
