Yale Lock w/ Ring & Hubitat simultaneously?
Sounds like you’re using the Ring Alarm system with this, is that correct? If so, maybe the Unofficial Ring Integration would be right for you. I used this when I owned a Ring Alarm system (sold it with my last house), and it worked perfectly. It allows you to use the sensors with both systems and should give you control of the lock from both too.
