Yale Doorman integration
Hi, I'm new to Hubitat and just orderd it yesterday...
I'm wondering if there is any integration with the Yale Doorman electronic locks?
Given that you linked the Swedish site I presume you are from Sweden :slight_smile:
I'm using the Yale Doorman lock with the Verisure module and wrote a driver which works with both the lock, smartplug, climate sensor & door sensor. Currently all Verisure stuff I have but should be easy to add support for more.
The driver is currently in beta and I have not released it yet but it's been working well for a couple of weeks now. Send me a PM if you have the Verisure module and want to test!
Does this mean that the Yale V2N communicates via Zigbee or does your driver communicate through some kind of API?
I'm looking to get a new lock for the main door and am considering either the Danalock V3 or Yale Doorman.
My driver communicates with Verisures unoffical mobile cloud api. There are both Zigbee and Z-Wave modules to Yale Doorman but all locks sold in Sweden are firmware crippled to prevent these from working and if you buy a lock from for example England it will not fit our doors here in Sweden.
Yale have partnered with August locks in Europe will release another hub and module sometime in 2020 that are suppose to be supporting Homekit but when and if it will be possible to integrate yourself with anything else is hard to say for now.
If you do have a Yale Doorman with the Verisure kit (no need for an alarm subscription) and want to test the driver send me a pm!
Hello,
I have yale doorman connected to verisure, did you have a solution so you could get it into Hubitat?
If yes I would like to receive a solution :slight_smile:
Sends you a PM
// Jens
