Sorry to bump an older thread; but is there any update on this? I've got the S5 linked with a MiConnector docker and connected to the Hubitat.
however I'm looking for a way to clean a specific room and make a command I can send with voice on alexa. On the app I have my Living room, Kitchen and Hallway all separated. Anyway to specify to clean those highlighted zones? I dont see any settings in the Miconnector app. I cant think of another way to go. I'd in effect like to be able to say Alexa, vacuum the living room twice or vacuum the kitchen 3 times. I can do it from the app but to do it from voice would be easier
I don't have a xiaomi vacuum cleaner although I have Mi connector set up for another device.
Maybe this might point you in the right direction, if it can be done in HA I would imagine it's possible on HE. I'd be interested to know, if we ever get a robot cleaner!
Hello ,
I need a help - i got my pi with docker,db,mi connector installed. I have roborock s6 max and getting following error in the mi connector ;( vaccum not supported
Now it was successfully registered without any issues.
Next, I tried to add device from mi connector (both side) but on hubitat nothing was found in the application and on raspberry pi I could not select vaccount to be added
In the end, the vaccum device appears automatically on hubitat side
Hello, I am curious, what did you configure at point 5 from your list in the docker mi connector files / where did you find the instructions from fison67?
I have tried a s4 and s4max, but the both show the same "vaccum not supported" error, now I am hopeful that they can be used with the same trick as the s6 max.
Thank you very much
