The battery is a brand new panasonic.
TBH I'm not that fussed as I have all my Xiaomi/Aqara devices connected to my hub using Mi-Connector.
I just left this one to see how it was performing.
I kept moving it around my house to see how it behaves but it just keeps dropping off the zigbee network.
As I have 2 hubs I have now re-enabled the zigbee radio on the 2nd hub and paired it to it. It has been rock solid on the 2nd hub in the same physical position that it keeps failing on hub 1.
Hub 1 is using zigbee ch 20 and hub 2 is using ch 22. My router is using fixed ch 1.
Ironically hub 1 has 3 devices that repeat (2 x Salus outlets and 1 x Aone dimmer) and hub 2 has none. Could it be the repeaters causing the issues? I'm not convinced as my zigbee network was rock solid until about 3 months ago and then started playing silly beggars hence my move to using Mi-Connector.
I only posted the info in case anything could be gleaned from the error code.
Had just a few Xiaomi motion sensor devices drop off at the outer limits of my house (monitored using Device Watchdog, an excellent app). Decided to get 2 IKEA Tradfri zigbee repeaters. Very nice little devices and a reasonable price too. Hooked them up and noticed several Xiaomi motion devices then disconnected from HE (not just those nearby, interestingly). Just left everything alone for almost 24 hrs expecting all devices to find their new route. Didn't happen. So I've just reconnected them with a short press to their reset buttons while in discovery mode. They all reconnected nicely. Now to see if they stay connected better than before!
"Once you put in monitoring" - is this an XBee thing or can the Xiaomi devices be configured to check-in periodically? I have a few Xiaomi devices that have been dropping off lately, even the 'last activity', on the device page, does not always seem to be reported correctly, but the device still works ok.
Hi, If this is not the correct place to ask this question please let me know.
I have setup a Aqara Vibration Sensor (DJT11LM) in my test environment and had a lot of success pairing and setup. I can see the sensor changing state from inactive to active and I believe I have set the "Closed Position" to Active and the "Open Position" to inactive. The issue I am having is that the contact state moves to Closed when the Active state is achieved but never returns to Open when the Inactive state is achieved. I want to use it as a vibration sensor on a clothes dryer to control a fan in the laundry room. Is this a limitation of the device or the driver. I am using the latest BETA release.
Hi,
Have this device, (Honeywell zigbee Fire Alarm Detector.)
Start zigbee pairing in hub,
Pressing on the button in the front (The one with the red led)
And it is just changing the sound volume
Pressing 3 times, 4 times, long press, ...
Nothing happened. it is not discovering.
Have I done something wrong?
@veeceeoh hasn't been on this forum since the end of February.
@WetCoaster What is referred to here is one of the ways you can monitor devices using either an App or RM.
@craig.allen.20 I might have time to look at that driver in a week or two, but as it is I don't think there is anyone on this forum who can answer you without checking the code. Patience
@9999341 I have one of those device but haven't even begun to look at it. I'll try to pair it soon and see what is up. One thing I can say is that these devices can be VERY sensitive to how good the mesh is. Especially during pairing. Try pairing it in close vicinity to the hub, if that resolves the issue it is a mesh problem. Ask about that in one of the proper threads You can @ mention me there and we can take it from there.
Hi
I should be receiving these 3 items tomorrow as I wanted to check if they would be "reliable" and stay connected to the HE. What I wanted to find out was what drivers I should be using for these
Mi Wireless Switch :YTC4040GL
Mi Window and Door Sensor: YTC4039GL
Mi Motion Sensor :YTC4041GL
These model numbers don't make sense, must be a sales model number used by someone, I think after checking the model numbers on the actual devices you will see which drivers will fit. YTC4040GL is most likely WXKGL01LM for example. The contact sensor is probably MCCGQ01LM and the motion sensor RTCGQ01LM.
Hi @markus you were correct the model numbers you gave me are the correct ones.. I have the Xiaomi smart button setup and wanted to ask how I setup RM, I basically want to know how the button pushes are labeled, So I have setup a motion lighting rule for the kitchen, what I want to do is press the button once to disable the lights from turning off even if motion is not detected. When I chose button as the option to disable turning off, the next option is;
Kitchen Button buttons to disable off? If I wanted to use 1 click to turn off would I put 1 and if I wanted a double click to turn this on would you put 2 , then a hold would you put 3.
I don't really know how this driver implements it, I use my own driver for this button. With that said, looking at the driver code, button clicks 1 to 5 would be button 1 to 5, so double click is 2. Held is a separate event and is 1 for event held.
It is not, I've not released it, I might if these drivers remain unsupported much longer, but I don't want to disrespect the hard work done be @veeceeoh. In mine, button press 6 would be held in addition to the held being 1. It does all kinds of other things differently as well, it is written from scratch and has nothing copied from this driver.
