Xiaomi & Aqara Devices - Pairing & Keeping them connected
Reportedly Osrams are terrible repeaters (and generally most bulbs are said to be quite bad at it). Probably shouldn’t waste your time there. Quite interesting that the Trådfri seem to work well (at least with Xiaomi devices).
Thanks for that. When the next one drops (just a matter of time). I’ll try pairing again but whilst as close to them as I can get. Whilst on ST they did stick like glue to the TRÅDFRI, hopefully I can get them doing this again.
@humac, I am building my own sensor/modules. I and a few member has tested the module to route Xiaomi sensors since the module is a Zigbee router as well. The latest iteration come with battery backup feature to help the case when the main power is down.
I've noticed over the last couple of weeks that my original Xiaomi Contact Sensors are either going inactive or not reporting correctly. Is anyone else seeing strange things going on with these devices. I only have 3 of these and am happy to replace these with the Aqara version if they are more reliable.
BTW. I've replaced the batteries in case that was the issue.
I always had issues with the original Xiaomi temperature sensors on HE. Originally they connected fine but after a couple days there would be no status updates. Recently i reset them and tried to re-pair but now they won't even pair correctly.
When I was on ST I had them working for years without issues
Today I finally migrated from ST to HE. I have a ton of Xiaomi sensors which is why I was originally developing the ST DHs.
We will see how they perform on HE...
If you are successful with a particular driver please post.
Changing the driver wouldn't help, because the issues you are having are not related to the drivers.
Dropped connection issues are due to any of the following:
  • Weak mesh network connection
  • Network interference from nearby WiFi routers
  • Xiaomi / Aqara devices connecting through an incompatible repeater device instead of directly to the hub
This thread contains a wealth of information regarding all of these issues.
This is not an interference problem as I have no other issues with any of the other 30+ zigbee devices I have. Plus I have ensured that my WiFi channels are not overlapping with my Zigbee channel either.
I also tried pairing 2 different temperature sensors within 3 feet of the hub with the same result.
I am not sure if the Iris plugs are incompatible, as they are not listed in this this thread as either compatible or not. But either way I was close enough to the hub that this should not be an issue.
I had no issues with these for years on Smartthings.
I have also tried new batteries.
Basically the sensors are seen as "device" and I have to switch the driver to the proper one. But even after this reporting is not working and in the logs it says "null" when refreshing the device.
Edit: I just realized that the Centralite 3210-L was listed as not compatible as a repeater, was looking for Iris but forgot this is the same device. I guess its possible that despite the temperature sensor being so close to the hub that it was still being relayed through one of my Iris plugs.
These are know to give issues with the Xiaomi devices. I had them at one point and had nothing but issues as they didn't properly route the Xiaomi devices. Once I replaced them things worked properly.
The latest devices that are getting good reviews for working with these devices is the ikea tradfri outlets.
Sorry that they are not listed in the first post, but Iris plus are rebranded Centralite plugs, and the general consensus is that Xiaomi / Aqara devices won't work when routed through Iris / Centralite plugs. I've updated the first post to add Iris to the list. For more details, do a search for "iris" just in this topic.
Unless you have an XBee and are using the XCTU software to map your ZigBee network, there is no way to know whether an end device is directly connected to the hub or is routing through a repeater.
You mention you have 30+ ZigBee devices, so you are close to or over the 32 end-device limit, which means even if you are pairing close to the hub, the device could still be forced to establish its connection through a repeater.
In my extensive testing and reading of other people's reports, not only are some repeaters incompatible in that they drop the connection of Xiaomi / Aqara devices, but also in some cases, messages from Xiaomi / Aqara devices aren't forwarded to the hub.
Well, a Hubitat hub is not the same as a SmartThings hub. The ZigBee hardware (and from what I understand the ZigBee software stack) of the Hubitat is different, so you can't expect everything to work exactly the same. The different signal strength of the Hubitat's radio alone means that the topography of the ZigBee network will also be different, because end devices will opt to connect to repeaters versus the hub based on signal strength.
The temperature / humidity sensor driver I ported over to Hubitat uses the same "fingerprint" data as in the SmartThings device handler to help the hub match the driver to the sensor being paired. I know this works correctly with dozens and dozens hours of testing with multiple sensors, both Xiaomi and Aqara, that I own.
If your sensors are being seen as a device then the data needed to match to the fingerprint must not be making it to the hub. This points to the possibility of routing through a repeater.
When you say that you see "null" in the logs after refreshing the device, I'm not sure what you mean. There isn't a refresh command built into the Hubitat driver. Also to understand better what's happening I'd need to see the log output.
I'm with you, there is no reason to change our working setup because the Xiaomi is incompatible, I have a very good working mesh, so I ended buying Iris v3 motions with temp and humidity, they work much better than those Xiaomi.
Yes I realized this after I posted that the Centralite 3210-L plug is the same as the Iris plug.
I suspect this may be the main reason, its very well possible that Xiaomi sensors are routing through the Iris plugs.
At this point I have too many of the Iris Plugs to swap them out and I do not believe that the Ikea ones have energy monitoring. The Iris plugs are also solid repeaters from my experience.
I think at this point since I bought a bunch of the Iris door and motion sensors on sale recently and they have temperature sensing built in I can use these to replace the Xiaomi ones.
The only places which I need something simlar to the the Xiaomi's would be in my Attic and Garage. Does anyone know of a sensor that does only temperature and humidity?
Use the iris v3 motion, doesn't harm having the motion as an extra/future use...
This would work although kind of a waste for the Attic. Too bad the V2's I have do not do humidity.
Yep, but they work with your setup, no need to change your complete set of Iris/centralite plugs because Xiaomi doesn't use the same zigbee protocol/stack/whatever as everything else.
I wanted to do my own test, those Xiaomi are great for paperweights in my desk....
I will probably wait for the V3's to go on sale, since now Lowes is selling off the Iris brand. The Iris sensors in generally have been solid for me, especially at the sale prices.
These are not compatible with Xiaomi sensors
Ever since I added a few Ikea plugs to my zigbee network I have not had any of my xiaomi devices drop off. They have also all rejoined the network after a power outage which with my Xbee's before would not do. I would have a 3 or 4 devices i would have to manually repair. I have about 12 motions, 5 moisture and 7 temp sensors and they have all been working great since the Ikea plugs were added.
That said I have alot of centralite sensors (motions, moisture, contacts, plugs etc) up for grabs so PM me if anyone needs to purchase any lol...
Mine have been holding steady.
The only one that is flaky on behaviour is the vibration sensor.
My friend has them but with the Xiaomi gateway. On the Xiaomi gateway if I place on the top of a wooden counter and tap the counter with it, it detects vibration. With HE nothing. I wanted to use it as a sensor for when someone knocks at a door. I could bang the door down in HE and nothing. Tried the 3 sensitivity levels.
For argument sake, I took mine and pair with the gateway. It works as expected.
How is your experience with them?
