Hi, any reason why this timer shows a strange values?
"Still waiting to stay -58:0-22:0-3 "
Normally it gives the time needed to trigger the rule, however the above is showing something really strange tied to restart the hub but still the same issue
Would you please post a screenshot of the rule. Also, if you hit Update Rule in the rule, it will most likely be OK going forward.
