The CocoHub App is still the busiest App but the Bridge device isnt in the runtime stats...
As things go things are running well and no notification of severe load.
Well... too soon to say for sure but I guess that's good news. Still seems really high though even if it isn't causing a meltdown.
It may be worth resetting the stats or even restarting the hub to get a more accurate picture of the aggregate result
I did this after making the change yesterday, however no harm in resetting now and then have a benchmark to monitor from
Up to you, I was only worried you hadn't done it after making the change.
I had one ZigBee network failure today as the network went offline and hub was unresponsive so couldn't do any troubleshooting
Will go back to the nightly reboot and see if it helps. Things are a lot snappier since the polling interval was changed
