Word spacing for newbies!
For some reason my space bar is totally useless in naming devices and writing rule names. Is this an issue or the way it is supposed to be? I have seen that certain symbols can cause issues but I would not think a space between words would. Other than that this is a slow process but works very well once you get it figured out.
Are you using some sort of non-standard keyboard layout? Spaces are perfectly acceptable and widely used in device and rule names.
Using an iPad with standard Apple keyboard. It was working but now it does not allow spacing. I am probably doing something stupid but haven’t figured it out yet so I thought I would post to see if anyone else had this issue. Thanks!
Did you happen to just update to iOS 16.2? Maybe that is causing the issue. I am sure some other people who work on hubs from iPad can chime in, or I may be able to test it on one tomorrow.
That may be it as I did just that. I am moving away from the Apple ecosystem and I found just now if I use my Pixel 7 I can space out so at least until I figure out the iPad issue I shall do it that way. Thanks for the help just talking about it is what I needed!!!
