With the new iOS shortcuts, has anyone done anything cool with h.e?
I use the alarm trigger to switch the mode from night to morning, have an nfc tag that unlocks my front door, set presence with it and have shortcuts for a couple scenes.
I’m disappointed myself.
I was hoping a shortcut could trigger by and off or on state of a switch... apparently it doesn’t....
What are you trying to do? You can definitely toggle a switch with An iOS shortcut.
Basically, you can create a shotcut right now that allows you to turn off your Apple TV.
However, I'm not able to trigger that shortcut using a switch.
I see, you’re trying to go Hubitat to iOS. Could you do that with home bridge?
No, it's a limitation with shortcuts not allowing you to setup triggers as switches or lights.
I think I'll just pickup a couple harmony hubs.
How reliable are they ?
For what?
I find my three Harmony Hubs to be very reliable, and I personally prefer using the Harmony remotes over the Apple TV remotes.
Yea, as a remote, I only use harmony
I just made a shortcut to turn on and off a light. You do need a bridge to HomeKit but it can be done.
You can go straight to the maker api with a shortcut. No need for homebridge.
