Wireless hose valve
Yes there is no way to integrate through zigbee. They do have a beta firmware with mqtt support, I have asked them to let me use it, and will look into it. Of course, you will need a mqtt broker, but at least it should work locally.
Ooh - that is very exciting to hear!
Has anyone tried one of these?
https://www.amazon.co.uk/dp/B08BHQBCDV/ref=cm_sw_r_apan_glt_fabc_0PXC5AQMSDSVDN4VQSST)
Would it work directly with HE?
I'm in the US and put together my own solution using a solenoid valve and outdoor plug... something like this to give you an idea:
Note: This was just a cursory search, I can't vouch for the specific devices. Also you might need adapters to fit your hoses etc.
In the US I wired an outdoor extension cord (with the receptacle bit trimmed) to the solenoid valve so I could use it with the outdoor plug.. has been working great over the last 3 years or so and the wiring was super simple.
Anyone tried the Wulian Smart Water Valve
http://www.wuliangroup.com/en/uploads/Wulian%20Smart%20Water%20Valve%20.pdf
I'm rebuildong my network after the lightning forced a move to C7 and am down to this Orbit hose valve. Anybody have pairing/re-pairing instructions for HE? An old thread on ST forums: "Did a factory reset, pulled the batteries, plugged them back in, and discovered" --hasn't worked so far.
Update - Found HE instructions:
https://docs.hubitat.com/index.php?title=Join_and_Reset_Instructions#Orbit
Was searching ebay for zigbee hose valves and this one came up. Anybody tried it on HE?
