With respect to hub slowdowns: We have said this before, but we think there is a resource leak, and one that is not easy to find. We have found and corrected one, and are testing another. These will be fixed. We wish it were as simple as most bugs are to find, but it has been very elusive. In most cases, setting up a daily reboot of the hub will completely mitigate this issue. We don't offer this a the solution, simply an observation of what seems to work -- for now, until we find and correct the root cause.
This issue has nothing whatsoever to do with the performance of the hardware. This is a software bug. Run the platform on stronger hardware, it would still exist, but perhaps the hub would run longer before the slowdown became noticeable. Still, not an argument for a higher performance hub.
For me, what a PRO version I'd be willing to buy is about;
Wifi Chip onboard
Bigger, Better, Stronger Z-Wave and Zigbee Antennas
For performance, I would hate to see a "more performant" version of this box as then all Community performance related issues (and god forbid, support's answers as well) would be about recommending upgrading to said box instead of actual root cause analysis of issues.
I fundamentally believe that a lot of performance/stability issues could (and hopefully will) be addressed at the software level of Hubitat.
I’ve moved all my automation off the hub and only using it as a gateway to my devices for now.
The speed of motion lighting has gone from 350ms to 70ms. And so far I haven’t needed to reboot the hub, but I do have a schedule to do it once a week in case of slow downs.
Hubitat has more to offer and works with more then what I’m using.
This effectively means that the problem is not within the slow serial Z-devices, at least in your case.
I also have slowdowns or regular crashes where the hub is unresponsive when hammering it with non Z-device traffic/events from LAN or cloud.
As an experiment I wrote a simple script on my computer that made 10 request per second to the hub for about 12 hours. The request where made to a non-existing page aka 404. Of course during the “D-DOS” attack the hub where non-responsive but even afterwards it was really sluggish and about 24 hours later the hub crashed totally. For any one interested it’s a C4 hub European version.
The main two critical features a "performance hub" or I'd be fine in adopting into the standard hub should have are:
Wifi capability - Numerous times it is stated certain devices need to be "paired next to the hub" yet the hub's location is generally fixed to only the limitations of your router/switch location and length of a LAN cable (with power nearby).
Battery Backup - Being that the database is so fragile to corruption, and that abrupt power cycling the hub is known to cause database corruption, there should be a preventative measure included.
Vera does this with their "top end" model VeraSecure, it has wifi and a battery that will run the hub for 4 hours when the power is disconnected.
I only have the following, and the rest are Lutron devices.
12 - Zwave Devices
25 - Zigbee Devices
Originally, I was getting motions delays of up to 700ms. I ended up re-doing everything using the built in applications where I could. Zone Motion, Motion Lighting, etc. This brought my speeds down to what seems comparable to everyone else. 350ms.
However, after two days of running I was finding the web interface becoming sluggish and my delays pushing up to 500ms at times. So I setup an auto reboot every day at 5am.
Just recently in the last week I converted all my automation over to Homeseer 4. (Still under beta, but running very well)
Two things I could add... A Z-Wave live log, similar to the Zigbee log and the use of webssockets in the Dashboard so it updates quicker without needing to poll. This would also eliminate the requirement (for larger systems) for selecting specific devices on a dashboard without incurring a performance penalty.
We just passed 120 SuperMicro based servers in my data center.
This is already done today for local dashboards, remote dashboards poll as you don't have access to that websocket (firewall/router). The impact in regard to "specific devices / all devices" comes with loading the dashboard, not updating it
The fact that Hubitat isn't interested in making a scaled up version is exactly why it will never be more than a small/medium piece of my home automation solution.... Basically an I/O hub.
I mean, I'm happy to not give them my money if they don't want it... And spend it with their competitors. That's their choice.
Realistically as competing solutions improve their zwave and zigbee support and add cloud and wifi integrations much faster than Hubitat, it makes Hubitat less important to my needs. Eventually probably unnecessary altogether unless they offer something the competition doesn't.
They're a great bunch of guys, and it is nothing personal. I like Hubitat, it's a cool platform for what it is, just maybe not scalable enough for my needs.
