Wifi problem
I'm having problems with some of my alarm contact/motion sensors not working in my dashboard.
In hubitat under Network Setup - it says "Network not detected"
My wireless router shows in "device list" that Hubitat is online.
What model hub?
Are the contact and motion sensors Wifi, Zwave or Zigbee? If they are not wifi sensors then they should continue to work even if the hub was offline for some reason.
Also, to test the hubs connectivity you can click the Network Test (from the network setup page) and then try the Ping.
