WiFi not able to connect
My wifi picks up a DHCP address and when I do find my Hub, it finds it but it won't connect. If I plug the Ethernet cable back in I can get to the wifi address that was assigned and also over the Ethernet IP Address. I have shut down the Ethernet interface. Also I am trying to move the Ethernet static IP to be the wifi static ip address all at the same time.
What is the issue that I am having? I want to carry it around the house to get my other hub's Zwave devices adopted using wifi.
Having the same problem. What did you do?
