I can not install the wifi drivers, when I push the button "install wifi drivers" it is just showing "working on it" and a blue circle keeps spinning, there is also a green circle spinning from time to time in the top right corner, I wait for literally 2 hours and nothing changes.
this is the info of my hub:
Platform Version
@gopher.ny may want to ring in here, but from what Iโve seen this could be a result of either no cloud connectivity (needed to grab the drivers) or a connection speed issue - believe you should be using the autonegotiated setting under Setttings|Network Settings.
Thank you for the quick response.
I switch to auto negotiate
I reboot the hub
it gives me this error:
Error: status code: 500, reason phrase: Server Error
it gave that error before i change the auto negotiate
but I updated the hub to the most recent version a couple of days ago
without any issue, any other suggestion ?
