Wifi Devices
Sorry I am new to hubitat.. I have a question about WiFi devices..
I have few light switches from meross .. From what I see, they don't have Zwave or Zagbee integration.. I have added them to alexa and can control the devices with voice..
Can these devices be added and controlled via the hubitat hub, or I have to go through alexa or native app if I want to use them..
Thank you.. Sorry if for the noobish question..
WELCOME TO HUBITAT!!!
There's a few different ways you can integrate these. Unfortunately, nothing it going to be all that responsive. You could add a virtual switch in Hubitat which you could then link to IFTTT. Meross has an integration with Meross as well. However, these devices wouldn't be controlled locally but instead through the cloud so they would be dependent on your internet connection. In addition, you are probably going to see a noticable delay in commands being executed. If you are using them for any application where speed is important, I would suggest swapping them out for something that is able to directly connect to HE.
Thank you .. that is was exactly my understanding as well..
