Why is this a thing? Static IP Setup, one step forward two steps back
Have you actually tried the Network Setup utility? That post is almost three years old, the tool has changed a bit since then, and I'm not sure that what you describe is a limitation anymore. If it is, you can still try:
PS - There is also documentation at: Network Setup | Hubitat Documentation
