Why doesn't this work?
signal = state.rssi if (signal < -30) { sendEvent(name: "rssi", value: "Excellent", isStateChange: true); } else if (signal > -67) { sendEvent(name: "rssi", value: "Good", isStateChange: true); } else if (signal > -70) { sendEvent(name: "rssi", value: "Poor", isStateChange: true); } else { sendEvent(name: "rssi", value: "Weak", isStateChange: true); }
NM I got it....
-30 dBm	Excellent | -67 dBm	Good | -70 dBm	Poor | -80 dBm	Weak | -90 dBm	Dead
signal = state.rssi
if (signal <= 0 && signal >= -70) {
} else
if (signal < -70 && signal >= -80) {
} else
if (signal < -80 && signal >= -90) {
} else
if (signal < -90 && signal >= -100) {
Hard to say if you don't say exactly what is going wrong, but the only thing I see is that you quite likely meant > -30 and not< -30.
EDIT: Or nevermind, you got it. :slight_smile:
Ya that was one mistake... I wrote it better which really works good now.
